HxC to replace an 8" drive
FCross
Post by FCross »
While I play around with getting the HxC to work with the FC1 interface board, I also have a pair of very old 8" drives that I would like to replace. I have the pinouts for the drive itself and I would have to make a cable since the drive uses a 50 pin connector. I know that not all of the control lines are needed with the HxC, has anyone made such a cable and would have the list of the pin to pin conversion?
Re: HxC to replace an 8" drive
FCross wrote:While I play around with getting the HxC to work with the FC1 interface board, I also have a pair of very old 8" drives that I would like to replace. I have the pinouts for the drive itself and I would have to make a cable since the drive uses a 50 pin connector. I know that not all of the control lines are needed with the HxC, has anyone made such a cable and would have the list of the pin to pin conversion?
I think that you can get got info there :
http://www.classiccmp.org/dunfield/img54306/cnct.htm
cube1us
Post by cube1us »
In addition, I recommend you look at the manual for the actual floppy drive controller and floppy drive hardware - there can be subtle variations, depending on what the actually controller used. Drive and controller information can often be located at "bitsavers" at http://www.bitsavers.org/pdf/ . To get a general idea of what the 50 pin interface pins are, you might look at the Sugart 800 series and the Siemens 8" drives.
zedex.us
Post by zedex.us »
I posted a cabling schematic at http://www.zedex.us/zendex-zx.html
Click the button on the bottom left of the Page that reads MDS-SA800-SA400 adapter.
This Adapter is for sale by Zedex.us
zedex.us wrote:I posted a cabling schematic at http://www.zedex.us/zendex-zx.html
this is seems different from the standard 50 pins shugart interface.
is it working ?
zedex.us
Post by zedex.us »
Nothing very standard about the SA800 interface, this is what it takes for the Intel MDS to Shugart SA801. Intel uses radial ready. What differences do you see Jeff?
