HxC GUI crashes importing SCP of Apple ][ disk
telengard
Post by telengard »
I have a flux image that is causing the app to crash when I load it.
I've verified I can write back the scp file and use it. I've placed the flux image up on my dropbox in the event it helps. Ideally I'd like to export it to .dsk or .nib.
https://dl.dropboxusercontent.com/u/155 ... ames_3.scp
I can re-image it with different options if it helps.
Re: HxC GUI crashes importing SCP of Apple ][ disk
Are you using the latest one ? (the beta version ?)
telengard
Post by telengard »
I thought it was the latest, the version is "v2.0.26.0".
~brian
telengard
Post by telengard »
Anything else I can provide to help debug the crash?
telengard wrote:Anything else I can provide to help debug the crash?
Use this instead :
telengard
Post by telengard »
Use this instead :
That worked, thanks. I guess my next question is, is there any way to export to dsk/nib/etc? I don't see it in the drop down.
telengard
Post by telengard »
Did you see this last question. Just wondering if you could add export support for A2 images (.dsk, .nib, etc).
thanks
