Recommended IIC display out of stock
alchemist
Post by alchemist »
The recommened IIC display for our Gotek device (http://www.ebay.com/itm/302110929185) is out of stock.
I don't know since when nor for how long.
Is there any other recommended display that can fit into the orgininal front panel?
Kind Regards,
Xavier Miller
Re: Recommended IIC display out of stock
alchemist wrote: Thu Jan 11, 2018 12:05 pm Hi,
Unfortunately i don't know : it seems that there are some shitty clones from "diymore.cc" working very badly flooding the market...
I can't guaranty that an ebay seller sold diymore bad screens or not...
A nice guy (You :wink: ) sent to me one of these screens. i will probably receive it Saturday and i hope to be able to make a definitive diagnostic and check if the issue is really fixable by something else than the current ugly workaround...
(Sometimes i think that i should really stop to support all these shitty hardware...)
alchemist
Post by alchemist »
Hi ;),
There is a Belgian seller, I will contact him for https://www.befr.ebay.be/itm/172919676616 and https://www.befr.ebay.be/itm/173066897606
and ask him if there are NO "diymore.cc" products.
Kind Regards,
Xavier Miller
alchemist
Post by alchemist »
Bonjour,
Non, Il ne s'agit pas du modèle "diymore.cc". La série que j'ai
est un peu différente du modèle en photo sur l'annonce mais j'utilise
exactement le même piloté par un attiny85 sur un capteur depuis des mois
sans aucun soucis. Je joins 2 photos que je viens de prendre.
Bien
cordialement,
I have ordered one ;)
Kind Regards,
Xavier Miller
DanielDOC
Post by DanielDOC »
I ordered this:
https://www.ebay.es/itm/272471495131
It is correct or not?
alchemist
Post by alchemist »
You cannot know : the photos are always the same. In my case, I ordered something like you, but the delivered item was different from the photo, it was a "diymore.cc"product, that doesn't work well.
You better have to contact the seller and ask him if the item is NOT a "diymore.cc" product.
Kind Regards,
Xavier Miller
@alchemist
Just got the package ! Thanks ! :D
alchemist
Post by alchemist »
@Jeff, have fun !
Kind Regards,
Xavier Miller
alchemist wrote: Sat Jan 13, 2018 10:05 pm @Jeff, have fun !
the diymore oled fix :
https://hxc2001.com/floppy/forum/viewtopi ... 196#p17196
alchemist
Post by alchemist »
Excellent ! 8)
Kind Regards,
Xavier Miller
alchemist
Post by alchemist »
The display is working very well. This is a huge difference compared with a diymore.cc display. The initialization is immediate.
Kind Regards,
Xavier Miller
