Ensoniq EPS
j1mpst3r
Ensoniq EPS
Post by j1mpst3r »
I'm having trouble loading sounds from the Quick Install folder for the Ensoniq EPS. I can load the OS ok but it won't load any of the sound files. I've read a few threads here regarding changing the Auto Select time to 1 second. Also seen others with the same issue and a mention that the sounds on the Quick Install folder may be bad?
Any help much appreciated.
I guess the next thing to try will be a save to the blank images and see if I can load from there.
EDIT
Working - formatting and saving to a blank image, then my instruments load successfully.
derf
Re: Ensoniq EPS
Post by derf »
j1mpst3r wrote: Tue Feb 22, 2022 5:36 pm
I'm having the same problem, Can you please describe how this works?
j1mpst3r
Re: Ensoniq EPS
Post by j1mpst3r »
Only just seen this. Hope you worked it out. No longer in my possession so didn't pursue.
derf
Re: Ensoniq EPS
Post by derf »
I've managed to get it working in the meantime.
