Can't Compile The FloppyEmulator Soft
kahtan
Post by kahtan »
I tried to compile the soft source code using Visual Studio 6.0 Enterprise Edition
i got error:
can't find the file: "./libs/capslib/Comtype.h"
i notised the all files in folder "capslib" are missed.
can you help me?
Re: Can't Compile The FloppyEmulator Soft
kahtan wrote:Hi Jeff,
i got error:
can you help me?
Due to some license issues i had to remove this lib from the sources.
add it by yourself:
http://www.softpres.org/_media/files:ip ... ache=cache
Why do you want recompile the software ?
kahtan
Post by kahtan »
i am trying to use Winimage SDK with yor software to generate hfe file directly from any file.
i mean:
first generate image file using winimage sdk the generate hfe file by one click
again i can't find the file: "./libs/capslib/CapsFDC.h"
kahtan wrote:i am trying to use Winimage SDK with yor software to generate hfe file directly from any file.
i mean:
comment the missing includes, this should compile.
there are already an FAT/DOS floppy generator in the software.
emrezanbak
Post by emrezanbak »
download file: [ADMIN]Sorry, no non-official download allowed[/ADMIN]
build ok.
Generating Code...
Linking...
HxCFloppyEmulatorGUI.exe - 0 error(s), 5 warning(s)
Regards.
i mean:
i forgot this:
If you don't need the IPF support, just remove "IPF_SUPPORT" from the preprocessor definition of the VC project.
kahtan
Post by kahtan »
emrezanbak wrote:Hi,
build ok.
Generating Code...
Linking...
Regards.
Hi emrezanbak
Thank you for you post.
please can you send me the links to email:
[admin]To avoid spam ... avoid posting Email on the forum...[/admin]
build ok.
Generating Code...
Linking...
Regards.
Hi emrezanbak
Again... :
And if you really need these files, ask to the sps team directly:
emrezanbak
v.1.5.0 build ok.
CapsLib.h
CapsForm.h
CapsAPI.h
CapsFDC.h
CapsPlug.cpp
CapsPlug.h
Comlib.h
Comtype.h
C.A.P.S. - The Classic Amiga Preservation Society
Access API, Open License Agreement
PREAMBLE
This distribution (the package collectively referred to as the C.A.P.S.
"Access API") is to enable "plugin" support for C.A.P.S. media images,
where the actual C.A.P.S. library (which has its own license, and is
available separately from the website) may or may not be present.
It is intended for commercial (for-profit) applications, or those
applications that have a commerical version (for ease of transition)
that are not allowed to distribute the actual C.A.P.S. library as
defined by the license that comes with the C.A.P.S. library. For
freeware applications, it is better to use the C.A.P.S. API directly
and those applications can ignore this distribution entirely.
LICENSE
This distribution, the C.A.P.S. media "Access API" can be statically
linked to any program. No actual functionality is provided however.
For functionality, users need to download the complete distribution
from the C.A.P.S. website, and that distribution is bound by its own
license.
Commerical distributions of software products should make users aware
that they can enable C.A.P.S. media support by downloading and
installing the offical distribution from the website where appropriate.
The source code in this distribution should not be modified for obvious
reasons, however, this "Access API" package can used however
appropriate and this license need not be included with distributions
of the software product.
The most current version of this license is kept on the C.A.P.S.
web site. Due notice shall be given if ever the license changes,
then all versions of the Technology will be constrained by the
newer license.
Copyright and Trademark Notices:
The Access API is Copyright (c) C.A.P.S. 2004. All rights reserved.
The documentation and all computer files are also Copyright
(c) C.A.P.S. 2004. All rights reserved. All other trademarks are the
property of their respective owners.
C.A.P.S.
http://www.caps-project.org
