firmware problem
pierrek
firmware problem
Post by pierrek »
I have a rev B SD board and updated to latest firmware, using the bootloader then the update
now when I turn it on it just red yellow LEDs flash, nothing on LCD
is there an older firmware that I should use?
Re: firmware problem
pierrek wrote:I have a rev B SD board and updated to latest firmware, using the bootloader then the update
Did you follow this procedure ? :
SDCard HxC Floppy Emulator Update procedure :
For users with the firmware V1.2.0.0 or above jump to the step 2) directly (No Bootloader update required)
1) Bootloader update (for users with a firmware below the version 1.2.0.0)
!!! Warning : DO NOT CUT the power supply of the board during the bootloader programming ! !!!
!!! In case of power loss, the device may be unusable and need a factory reprogramming. !!!
-> Copy the new bootloader file (HxC_SD_Bootloader_V1_0TOV1_1.upd) to a freshly formated FAT32 SDCard.
-> Press Left and Right buttons before power up and keep it pressed at least 1 seconds at power up.
-> Wait some seconds. When 2 leds are blinking (Sdcard access led and Floppy Access led) it's done !
(to be sure wait 1 minutes before removing the power supply).
After this the firmware must be flashed. (Please go to the step 2: Firmware update)
2) Firmware update
Note 1:
The file must be unfragmented on the sdcard and must be in the first part of the root directory.
For these reasons it is recommended to use a freshly formatted FAT32 SDCard, otherwise you may get the error 4 or 6 (see note 2).
Note 2:
Bootstrap LED error messages:
Error 2 : (blink 2 time and 2 seconds pause cycle) SDCard init error.
Error 6 : (blink 6 time and 2 seconds pause cycle) Bad data crc! (file corrupt)
Error 8 : (blink 8 time and 2 seconds pause cycle) Write error (Pic flash error)
Jeff / HxC2001
pierrek
Post by pierrek »
yes
pierrek wrote:yes
How blink the LED ?
pierrek
Post by pierrek »
red , then yellow, looping
pierrek wrote:red , then yellow, looping
What means "looping" ?
Can you make a small video of this ?
Have you retry to format the sdcard in fat32 and copy the firmware file and after this update the emulator with this sdcard ?
lotharek
Post by lotharek »
i think You programmed PIC not properly with corrputed file.
Anyway, if main CPY code is destroyed, i here to help - just drop me an email - will help for sure :)
..... Atari Roxxx !!!
pierrek
Post by pierrek »
redid the firmware install, seemed to work now
But now cannot read any SD cards (No SD-card found message)
with read LED remaining on
-Pierre
pierrek wrote:redid the firmware install, seemed to work now
-Pierre
Have try another SD Card ?
